ControlNet (CLX) to DH+ (PLC-5) MSG path
Papplebeast
Oct 2014
Missouri
I'm trying to set up a MSG path between a CLX processor on ControlNet to a PLC-5 processor on DH+ and I cannot figure this out. The first attached image is a photo of RSLinx with the source (BLUE) and destination (RED) highlighted. The most recent path I've attempted is in the second attached image. The CNB card in the CLX rack is in slot 3, so I've started the path with 1, 3 and it ends with a 6 with DH+ channel and node set properly.
Any help I can get on this would be greatly appreciated.
I was troubleshooting an apparent loss in communication between a 1756-CNB and a ControlNet module (plugged into Brabender Controller). I...
1,928
I'm going to be doing a project and need 24 120 VAC inputs and 16 relay outputs. On Point I/O I was going to use IA4 and OW8 modules. On Flex I...
3,757
I have CLX Processor using Controlnet, I have 7 remote Point I/O modules everything is fine on the Controlnet network, But when I go to save the...
1,510
Trying to perform scheduled ControlNet connection between 1747-SCNR/A FW Rev 1.4 and 1756-L55/A !756-M12/A Revision 12.25. Following example in...
4,107
4,497
