cmore hmi email via gmail
olsq
Apr 2011
Houston area, TX
62
i have successfully been using a cmore ea9-t10cl to send emails via gmail. nothing fancy just a couple screen caps twice a day.
nothing changed but late last week it quit sending and started returning an rte-041connection failure (smtp.gmail.com)
no help from automation direct tech support. their test mule is sending emails. my IT dept says their is noting preventing a connection to gmail. new hardware yeilds the same result. a new yahoo email wont work either.
i was just wondering if this vast circle of knowledge had any idea.
all login credintials have been double checked.
thanks in advance.
Olsq
Thank you. My fix was to move away completely from gmail. i started using the company stmp server that is reserved for copiers. so far so good.
hMailServer relay
I'm having to use a locally hosted email server as well to bridge/forward between my local network and my email host (zoho). I'm having a bit of trouble configuring my hMailServer to act as this bridge - do you mind explaining what you needed to do with your hMailServer settings to get this going?
Hi everyone, recently i worked with a cmore panel and have the question that how can clear alarm list whit remote form,right now only can with...
109
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400….. to a Cmore 10...
495
I working on installing a EA9-RHMI so I can use a TV screen for my HMI. I wanted to be able to show multiple screens on the TV at one time, but...
1,315
I am stumped here. Anytime I put the PLC into run mode the HMI comes back with PLC-497: error code 0x010100 returned from PLC on CIP and also...
1,999
Has any one connected the Cmore panel to an Omron NJ PLC if so how? I have been reading up on the FINS communication protocol, Seems a bit fuzzy...
2,539
