Jordan13
Hey everyone,
I am currently in the process of building a PLC based project at my college. I am looking to build an “Automated Golf Putting Green”. It would be built in a wooden frame with a trampoline/turf putting surface. I am looking to automatically adjust the contour of the surface through use of actuators underneath that are controlled using a PLC with digital I/Os. Simply put i would have a sensor at in the hole that would input to the PLC to adjust the actuors to either on/off for that hole pattern. It is going to be a 9-hole game with 9 different patterns for the actuator array.
My main question is does anyone have any suggestions for a PLC that would best get this job done? Also does this sound doable?
My budget is about $350 for a PLC
Thanks you
Thanks you
