Com Profibus V5.1
Jason Lee
Jun 2012
NewYork
Dear All,
How can i go online using Com Profibus V5.1
Which particular cable do i need?
and what is the Procedures to go online?
When i try to go online
File>>>Import>>>DP Master
it detected the braud rate, but after some time it says Station is Switched off etc.
i don't understand Why?
I use ComProfibus V5.1 SP2 HF3
and Windows Xp
Cable: CP5512 and MPI Cable
PG PC Interface is set to Com Profibus
I also tried with Simatic M2 PG with built in CP Card but same problem.
If anyone has any idea about this please reply,
i also need a Com Profibus Software Manual
I would normally use a short piece of profibus cable but MPI uses the same connections so it should work.
There are two variants of the IM308. The IM308-B uses an orange EPROM and I'm not sure whether can read from it via the profibus interface. The IM308-C uses a flash card and you can definitely read the config via the profibus port but only if it has a configuration in it. if you have a flash card without a configuration in it then you will need to use a Siemens programming device to put a configuration on to the card before you can communicate with it.
Nick
I'm looking at an old Profibus configuration on ComPB 5.1 and upon loading the .et2 file I get an error Upon loading an old configuration et2...
1,990
Hi all, I have a blown film line with a Siemens 555 plc, 26 profibus slaves and 2 devices conected on the MPI network. I have Com Profibus...
3,006
Hello, I have a problem, right now i have a empty memorycard for the IM308C and it isn't possible to program it via the profibus port on the...
1,663
I have COM Profibus 5.1 w/Hotfixes 1,2, and 3 applied running on an XP platform. I am attempting to import a bus configuration via the USB...
6,375
Hi My devices are as follows: S7-300 > CPU 315-2DP (6ES7 315-3Fx-0AB0) PROFIBUS CP342-5 (3425DA02-0XE0) ASi CP343-2...
4,981
