COM: Unspecified error
todd066
Nov 2015
Lynchburg
I have a program that writes numeric inputs to the PLC. The program will not write the first 8 - 12 tags but then writes the rest of them (about 200). I am using the downloadAll command in RSView32 to perform this function. If I continue to run the download all, the information will eventually get into the PLC. Also, if I go to each numeric input and press enter the information is written. I get the errors: Can't write to tag XYZ followed by COM: unspecified error. Any ideas?
Thanks for the reply. Unfortunately, the thread did not apply. The issue is that I have other computer/PLC combinations that are running the same code without issue. This one is just acting funny. I ended up changing the button to set the focus on the offending information on the HMI and downloading that number and then incrementing to the next number. It is a brute force method, but it worked. Still would like to know that the actual fix is if you have any ideas.
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
246
I'm retrofitting equipment, but I didn't want to change the electrical characteristics of the panel. In this equipment I have a dedicated...
75
Hi folks ! Got an older Modicom BM85 and I suspect that it's not passing data to ModBus+ network. We had a power loss for a few days and I suspect...
70
I need to recommend a PC to replace a customer's old Windows 7 computer. The only thing I need to think through is the serial com port to...
21
715
We're upgrading an old PLC-2 system programmed in ICOM. We have the files, the PLC logic is in a .LAD format. Does anyone have working...
430
