Comm Problem: PV-550 DF1 using USB<> RS232 converter
Scott180zip
Oct 2008
Brunswick, OH
Setting up a PanelView-550 to communicate with Compact Logix, using a laptop to set it up. DF1 using USB<> RS232 converter using a BELKIN, continual COM problem. PV will not consistently respond using Autoconfigure using RSLinx Classic. Anyone have any suggestions, sometimes it works - sometimes not but it always crashes. This time I cannot even get it to start. Very unstable. 19200 Baud, 8 bits/ 1 stop no handshaking, BRB. Using A/B cable but need to use a NULL Modem. I gave up on the Laptop communications and connected it hooked to Compact Logix processor RS-485 Port which will not recognize it either.
Note: using PV32 Software
The proper cable for communication between your ConpactLogix's serial port
or your laptop is a straight thru cable.
A USB to Serial adapter that works is the "Keyspan USA-HS19" ( see link below) for one source.
It might also help us help you if you provide the complete catalog number of your PV
http://www.plctrainer.net/
Model No. is 2711-T5A16L1 thanks... Q: Why does the Belkin USB work intermittently?
I don't have the expertize s to answer that. I do know that some adapters work some don't. Others here have had great success with the "Keyspan" brand.
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
514
Hi, I am trying to do a very simple program to communicate the PLC with Hyperterminal. I am using a new CP1W-CIF01 Optional Board (RS232) with...
2,555
Looking for anybody that has experience using the older PV550 displays. Have a locked up comm port. Is there any hard factory reset procedure...
1,369
Hello everyone , I have an engineering station with step7 program. I can make the modifications from this PC for 7 PLCs. But now I can not...
1,927
Hi, First post, I am new to this forum. I tried searching with no luck. I am using an Omron PLC - CJ2M CPU32,and I am trying to get it to...
2,398
