Communicating with a PLC 5 ?
Rob S.
Sep 2008
Maryland
739
Good Morning,
What is the best way to communicate with a PLC 5 processor ? I have a D3-DSCBL-2 cable . Would that work ? If so , which driver ? I am trying to use a 1784-PCM6/B cable with a AB_KT-1 / PCMK Driver. No luck.
Thanks.
Which model PLC5?
The PCM6 cable gets you in to the DH+ port.
I don't know what the D3 cable is and haven't time to research it.
Have you used your PCMK card on anything else?
You made sure that when you chose the KT1 driver, that you chose PCMK as the Device and DH+ as the network(from what you wrote, I believe you did).
Did you try the Auto-config - I know some of the networks have an auto-config mode; I don't recall if the DH+ does. You may have to check your network speed as well - 57.6k should be the common one.
Network - DH-485 ( it says card supports DH+ also ). In diagnostics it is sending and receiving packets. Node 8 is found. Who active , go online in RS Logix 5 I am looking for Online to go bold. No go. It seems like everything is good.
Dear All Please help me about Below picture problem.PLC not communicating proper.
188
Hi All I'm trying to connect two zebra printers to th PLC through Ethernet. I can ping the Printer through my laptop connected to the private...
373
Hello again all, This is sort of a follow-up to my last question a few months ago. Here is my situation: I have a LAN with an IP scheme of...
6,713
I'm not sure exactly what is going on. I am attempting to communicate with my plc and my HMI, but I am unable to go online with either one. I am...
1,447
Hello, friends. I've programmed a ControlEdge 900 PLC (900CP1-0200) and I now have to make an HMI application for a 900 Control Station...
2,057
