Communication between S7-200 EM277 and Premium PBY100 via Profibus
Jeanne
Jun 2005
Siemens register address is VW. Schneider's address is 96IW. How to convert signal between them? Appreciate any comments.
S7-200 Configuration on profibus
The S7-200 is only a slave on the profibus network. I assume the PBY100 is a master. The S7-200 address starts (eg:vw100) as the inputs coming from the profibus master. Depending on the number of configured words determine the address of the VW going out to the master. (vw100 + number of configured ouput bytes on the master's configuration eg: 16)= vw116 address for outoging bytes to master. I might have the input and output order reversed. but essentially it is just a mailbox with incoming data and outgoing data.
One additional note
The address in the profibus master may or may not have the same input and output address. In a Siemens master you usually make the inputs and outputs to a profibus slave the same (2 registers.) There are other PLCs that do not support simultaneous addresses for inputs and outputs (1 register) I hope I haven't muddied the water too much.
Hi all I have micro logix 1200 and automation direct panel (EA9-T6CL). I have downloaded .RSS file in micrologix 1200 using 1761-CBL-PM02...
1,811
Dear Experts, Good day I have to make ethernet communication between S7-1200 ( 1215c) and Beckhoff PLC CX5010. My question here any expert can...
4,295
Developing Communication between Energy Meter(Indigo+ Schlumberger) & SIEMENS S7-1200 Hi Members, I am Currently facing a challenge regarding...
1,503
problem in communication between micrologix 1200 & Panel View 600 Plus by serial DF1 Hello Friends i have to do communication between micrologix...
6,638
Hi ! Everybody ! Please..help me about communication between S7 1200 and inverter or any varispeed inverter had MODBUS support by module CM1241...
20
11,201
