Communication CP341-RS232C Siemens
RoRo
Jan 2009
Overijssel
I got a problem getting the CP module to work. I can access it and set the parameters of the module. Im trying to send a message using the P_SND_RK function_block,
This is my call of the block
A I 4.0
= L 0.0
BLD 103
A I 4.1
= L 0.1
BLD 103
CALL "P_SND_RK" , "DB_SND"
SF :='S'
REQ :=L0.0
R :=L0.1
LADDR :=288
DB_NO :=2
DBB_NO :=0
LEN :=10
R_CPU_NO:=
R_TYP :=
R_NO :=
R_OFFSET:=
R_CF_BYT:=
R_CF_BIT:=
DONE :=Q4.0
ERROR :=Q4.1
STATUS :=
I want to send 10 bytes from db 2 through the module when I trigger the input 4.0. The modules address is 288 to 303.
The parameter settings of the module are 9600 baud, 7 data bits, 2 stop bits, parity bit even. This is because I want to communicate with an E5CK temperature controller with these settings. The SF led is out, the TXD en RXD led dont go on so there is no communication what so ever. Am I doing something wrong?
And does the module send out data without being correctly connected?
The status returned nothing. The was no error or done either. Somehow it works now. I didnt change anything :unsure:. But thanks anyway
Hello, I'm busy with software to receive RS232 (ASCII) from a PC. The software what i made works BUT... My sofware is based on receiving frame...
1,549
Hi Friends, In my one of the Project Using Siemens CP341 ( Communication Processor). I am facing problem for modbus communication between CP341...
5,030
Hi! Does anybody know, if I can connect to 2 or more PLCs with one CP341 module? I have connected with S7300 PLC (CP341 module) to Unitronics PLC...
4,163
Hello, There are 3 different types of CP341 (RS232C, 20mATTY, RS422/485). Does anyone have suggestions concerning wich type I should choose...
1,967
I have a problem with a CP341, When we did tests, the communication worked fine... But now after mounting in the closet, it's really slow and...
22
5,430
