Communication S7(cp341) with S5(cp525)
Annick
Jun 2006
Antwerp
Hello,
There are 3 different types of CP341 (RS232C, 20mATTY, RS422/485). Does anyone have suggestions concerning wich type I should choose?
Advantages? Experiences you have? Tips?
Thanks you,
Annick
Hi Annick
You need to check the spec of S5(cp525).
They both need to have common language(platform)in order to successfully talk with each other.
Hello, I'm busy with software to receive RS232 (ASCII) from a PC. The software what i made works BUT... My sofware is based on receiving frame...
1,549
Hi, I got a problem getting the CP module to work. I can access it and set the parameters of the module. Im trying to send a message using the...
3,380
Hi Friends, In my one of the Project Using Siemens CP341 ( Communication Processor). I am facing problem for modbus communication between CP341...
5,033
Hi! Does anybody know, if I can connect to 2 or more PLCs with one CP341 module? I have connected with S7300 PLC (CP341 module) to Unitronics PLC...
4,164
I have a problem with a CP341, When we did tests, the communication worked fine... But now after mounting in the closet, it's really slow and...
22
5,430
