The same way you would any other computer monitor???
You'll need a computer running the HMI application which is communicating to the PLC. Run a DVI cable to the TV just as if it were a monitor? (assuming you are using a TV with a DVI connection)
I'm really confused as to what the complication is?
not really, have an Advantech touchpanel on wall at home acting as a jukebox and doing lights/pool.
(and kids like using it for drawing pictures on paintbrush)
I would have used widescreen TV monitors in a couple of cases, if only WinCC Flexible had supported the wide-screen formats.
You might want to check-up on that your HMI or SCADA do support wide-screen.
I've seen some nice setups that do this. FactoryPMI doesn't have issues with unusual resolutions. A few tips:
1. Favor LCD over plasma in general
2. Use DVI or HDMI (adapters or cables convert between the 2), not DB15/VGA if possible
3. "extenders" can push the signal over Cat 5/6 cable. This is NOT typically Ethernet - ie, don't use a switch/hub, just the cable.
