Hey guys,
I can't connect annymore with a GE Fanuc Serie 90 micro controller. The OK and RUN light are blinking. I try to connect using PME(v6.00 on xp) but whenever I want to go online it keep retrying and never connect. I tested the port with the Serial Communication Test Utility and it returned "PLC Connected OK at 19200/odd/1 use VPv2" and I use the same setting in Target properties window.
I know the cable(IC690USB901) work because I tested it on an other plc from the same family. I don't have any backup of the program in the plc so a hard reset is not a possible option. Logic Master 90(v9.02) was used to transfer the program into the plc.LM90 wont connect either, when i go online i have the no communication error. I lauched the firmware update utility(3.10) and I am able to attach to slave but i didn't go futher in case this erase the logic.
thanks
thanks
