Communication Problems Between 317 PLC And IPC 577c Using WinCC Flex
hein123
Aug 2010
Uitenhage
93
Hi
I am having problems with coms from the PLC to a IPC 577 c device with Win CC Flex 2008 as my SCADA program.
I can download to the device but no indicators come on.
When I set up the WinCC project from my laptop everything works fine.
When I setup the IPC 577c in Netpro I used a onboard CP 1616 device, is this correct or is this an add-on card?
Is there anything else I must setup on the IPC Device for coms?
Please advice
I think your onboard CP1616 is correct.
Post screenshots from the connection setup in WinCC Flexible, and from the HW Configuration in Simatic Manager.
Is the "Station Configurator" program running on the IPC577C ?
If so, post a screenshot from this program.
I am just stuggeling to upload these pics, but currently I have no Station Configurator running on the IPC, is this necessary?
I don't have the S7RTM ticked also in the NetPro.
Does this mean I habe to get Simantic.NET?
But this is one thing I do not understand, why is everything running fine on my laptop but not on the HMI?
I currently have no Station Configurator running on the IPC, is this necessary?
Also when using the CP 1616 onboard module I see taht it uses 3 connections, however the IPC does only have 2 TCP/IP plugs, that is why I am asking is the CP 1616 the correct card
You WinCC Flex application uses S7ONLINE. That is why it runs on your laptop.
Simply remove the onboard CP1616 from the configuration, and set the S7ONLINE access point on the IPC577C in the same way as you do on your laptop (via the Set PG/PC Interface utility).
It is also posssible to setup the configuration as a "PC Station"/S7RTM/Softbus. But unless you need other goodies (OPC Server, Routing, whatnot...) then there is no direct reason to do so.
I have sorted the problem, I feel so stupid as at the end my WinCC app was sacriviced as a accidently deleted it :)
What I did was to keep my config as is and on the IPC went to Set PG/PC Config and I used the wrong TCP/IP port
All way how to learn is to stuggle
unexpected problem happening when connecting said panel to a CJ2M-CPU35 via Ethernet (was replacement of broken NT21 via NT Link). The machine...
652
The panelview 600 is connected serially with a Flexlogix 1794-L34 controller. The panelview firmware was upgraded to 5.00.08. On my laptop I am...
4,654
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
905
Hey everyone, I am trying to communicate with a Slc 5/04 plc using the 1747-cp3 cable, RS232-DF1 driver and a laptop. I tried using a serial to...
3,113
I have a question on an install I did last week one of you guys may be able to help me out with. I don’t have all the model #s of the PLC and HMI...
19
6,040
