Communication with CP341
dwcy
Oct 2004
Hong Kong
22
This is my first time to use CP341. In my system, there are two CP341 modules, one work as Modbus Master and other one work as Modbus Slave. The Modbus Master get data from three Chiller controllers and then the Modbus Slave provide data to BMS of the building. I found some application example for CP341 about the Modbus Master and Slave, however their are in STL language. Anybody have application example in Ladder Diagram? ThankS!
Hello dwcy, this may not help at the moment, but if you can wait about a week i should have finished commissioning my first S7300 job :( , in which i have used 2 x CP341 modules (one acting as Master to two Atlas Copco compressors, the other acting as a Slave to a Honeywell DCS system).
I too found the STL a little weird looking at first, but now i feel i know the comms side inside out (had no choice!). The Slave side is dead easy (a little bit of initialising and then basically set a start address for the Modbus mapping - then it's up to the BMS people to configure their side to do the controlling). The Master side wasn't as straight forward, but still managed ok.
More than happy to share the code when i've completed.
Hope this is helpful. ;)
I also have an app w/ CP341-11 modbus slave (s7-300 system) to Honeywell Experion (master). I am need of a go-by example to set-up.
Did you finish your start-up. Thanks
Hello, I'm busy with software to receive RS232 (ASCII) from a PC. The software what i made works BUT... My sofware is based on receiving frame...
1,550
Hi, I got a problem getting the CP module to work. I can access it and set the parameters of the module. Im trying to send a message using the...
3,381
Hi Friends, In my one of the Project Using Siemens CP341 ( Communication Processor). I am facing problem for modbus communication between CP341...
5,033
Hi! Does anybody know, if I can connect to 2 or more PLCs with one CP341 module? I have connected with S7300 PLC (CP341 module) to Unitronics PLC...
4,164
Hello, There are 3 different types of CP341 (RS232C, 20mATTY, RS422/485). Does anyone have suggestions concerning wich type I should choose...
1,968
