Communications, IP address, stratix 6000 switch
plcisgreat
May 2005
Norfolk,NE
58
I'm having a hard time with communications. I have 1761-net-eni networked to a stratix 6000 switch. Can I access the network by connecting my PC through RSLinx and through the stratix 6000 switch? How do i setup the IP address in Linx and the laptop?
The IP address labeled on the side of the 1761-net-eni is
00204A8A9331. If that is the IP address, wouldn't "A" be part of hexadecimal. Like I said, communcations, IP addressing is out of my comfort zone.
That address is a hardware identifier called a "MAC ID", and you associate an IP address with it.
The simplest way to do that is to connect both your computer and the 1761-NET-ENI to the switch and use the BOOTP-DHCP Server utility that comes with RSLinx and RSLogix to watch for the NET-ENI announcing its BOOTP requests onto the network, then assign the NET-ENI an address.
The other method is to use the NET-ENI's serial utility to set up the module using the serial port and a 1761-CBL-PM02 cable.
But very first, you need to make sure that you have an appropriate IP address assigned to your computer's Ethernet adapter.
Have a machine we recieved that has two omron cp1l plc's. Have the program and in PLC#1 it is using what appears to be 3100 - 3100.14 to recieve a...
1,485
I've been dealin with some intermittent CIP explicit messaging issues. I tried reducing the amount of small MSG instructions and converted them to...
188
Hello, I'm trying to delve a little into rs-485 communications for a couple projects of mine. Until now I've been using a delta vfd and a delta...
129
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
164
I have a curious question and I can't seem to find any information on it. I'm hoping I'm just overlooking something simple. I have 4 machines...
473
