omron pc link communications address
irondesk40
Jan 2008
nc
630
Have a machine we recieved that has two omron cp1l plc's.
Have the program and in PLC#1 it is using what appears to be 3100 - 3100.14 to recieve a signal from plc#2.
PLC#1 also is using 3110.0 - 3110.14 to send a signal to PLC#2
Could someone explain how these address are assigned. I understand in both plcs, the serial port 1 is set up as PC Link, but do not understand how it is set up to use the 3100.00 - 3100.14 .
I come from an AB background. My current job has a lot of Omron devices. We have a couple systems with NX102's with numerous IO link devices...
654
Dear colleagues, I've made a couple of projects with Omron PLCs, still, I can't figure out a quick solution to this one. I have a CJ2M-CPU32...
2,376
Hey guys. I recently added a barcode scanner to our network. I can see the device through network configurator. When trying to set up the tag...
1,630
I have an Omron Sysmac C28K PLC with a 3G2C7-LK201-EV1 Host Link Unit on it, I am able to connect with SYSWIN 3.4 without issue. I also have an...
3,458
I have put together a post to read memory areas from the Omron PLC using VBA. This is a serial communication using (Sysmac Way) Host Link...
2,931
