compact logix and maples hmi
irondesk40
Jan 2008
nc
630
Hope someone can lead me in the right direction.
Have a machine that has a compact logix plc and a maples 5071L HMI.
Machine is running fine but trying to figure out how to go on the maples HMI and create a object on the screen so that the operator would enter the text such as for example the word NAME.
Then in the plc if it sees the word NAME was entered then it would execute a certain section of code in the plc
I have experimented with creating a ASCII object on the HMI and creating a new Tag in the plc referenced as a string but not having much luck.
Would anyone have a example they could share?
just in case anyone else has to do the same thing.
Finally was able to put enough fires out and sit down and think through it.
In the compact logix i created a new Ascii Tag, then in the Maples using the EZwarePlus software created a Ascii Object and assigned it to the PLC tag and with Data Format set to Unicode and it worked.
have a project coming up that will involve using a maples hmi and a compact logix 1769-L24. In the logix5000 software i see where you have a...
1,376
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
137
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
142
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
212
I am having trouble with getting no control of my analog output signal. I am using the SCL function block to control my analog output. The logic...
307
