compact logix and s7 1500 communication
chandrapaul
Mar 2016
bangladesh
119
Hello,
I have an Allen Bradley compact logix controller and s7 1500 plc. i will connect both plc with ethernet cable. i want to use the tags of the compactlogix plc in the TIA portal. i will make some ladder logic in tia portal using the tags of the compactlogix . then will download the program into the s7 1500 plc.
how can i import the tags of the compactlogix into the TIA portal?
Please let me know the step by step procedure. i need your help.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
98
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
114
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
205
254
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
139
