Compact Logix Loss Date & Time
Raul_Robins
Sep 2013
mexico
Hi everybody,
I have some problems with a compact logix l32e, when i turn it off the PLC loss de Date & Time, when I check the date i just see question marks, I already change the battery and the PLC is connected through a voltage supressor , any idea of what could be the problem???:confused::confused::confused::confused:
http://imgur.com/2CXvaNU
2CXvaNU
566038 - Date and Time display as ?? on Controller Properties Date/Time tab
Access Level: Everyone
Is erroneous data possibly being written to the hour or other with an SSV you don't know about?
Something is invalidating the data for the Date/Time?
Regards,
George
I have a 1769 Compactlogix here with 2 analog cards in it. My problem is when there is a power loss or cycle of power the system starts fine but...
4,190
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
95
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
105
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
205
251
