Also, as daba and others suggested, get rid of the oneshot. It's not required.
The only thing you'll need to check is the functionality - there are two possibilities on how this is supposed to work:
1. Button is pressed, system waits until certain parameters are met (i.e. LIM instruction), and then when they are met, action is taken (i.e. MOV instruction) and button is reset
OR
2. Button is pressed, and as long as certain parameters are met (i.e. LIM instruction), then take action (i.e. MOV instruction) and reset button. If the parameters are not met at the time of button-pressing, no action is taken and the button is reset.
If the required functionality is as per option 1, then just delete the ONS and you're on your way. If it's as per option 2, then move the OTU so it's immediately to the right of the XIC, and delete the ONS.
