compact logix to proface
Dec 2005
Christchurch
We urgently need to connect a Proface operator display (Proface GP37W2) to a Rockwell compact logix L31 .
We need info on
1.How to set up the addresses/tags in the Compact logix so the proface can read and write data.
We have set up the Proface to read/write N7:00 to N7:50.
If anyone has donne this successfully it would be very helpfull to us to
get some info which will help in getting this done.
JA
You need to use the PV mapping tool in Contlgx5K to set up the tags.
Use the Logic Pulldown menu and click on Map PLC/SLC messages.
This will set up the direct mapping for the integerst that you have specified.
Check out the manual for using PV tags in contrologix help.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
98
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
114
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
205
253
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
139
