Compact Logix To RSView 32 Communications
wes_h_13
Dec 2010
Lloydminster
Hello
I have a compact logix L5573 that is going to be talking to three computers running RSView32. The most tags I will have is 5000. I have been reading lots of topics about communication optimization between Control Logix PLC's and RSlinx classic. It is a bit of a pain and a lot of extra work to organize everything to array files. Do you think this is necessary with this type of processor.
If I do need to optimize. If I create an array of UDT's does this help communications or do the arrays have to be of the native tag type (I.E FLOAT,DINT,INT). Any help would be greatly appreciated.
Using arrays is always helpful when optimizing communications between a SCADA/HMI computer and a controller. If you want the very best communications performance, use arrays of Atomic (DINT, REAL, BOOL) tags.
Arrays of UDTs are less efficient, but still far more efficient than addressing individual tags.
A sort-of-related example; a recent thread involving a DCS interface that was given random access to a PLC-5E data table was able to be reduced from 13 seconds poll rate to 1 second poll rate by optimizing the reads and writes to a handful of Data Tables instead of individual elements of timers, counters, integers, floats, and PID control blocks.
If you really want the best performance, set up one of those computers to be an RSLinx Classic Remote OPC Server, and let the RSView32 computers get their data from a single instance of RSLinx Classic.
Has anyone have any problems with direct referenced tags from 1769L31 via a Net ENI to ME Station showing intermittent data and occassionally...
1,520
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
98
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
114
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
205
254
