compact logix versus control logix CPU
Nilesh Sinha
Sep 2005
Ranchi
I have an application where I need hardware based redundancy, with a processor switching time of less than 100 milliseconds.
Can I use Compact logix for this application.
Can anyone tell me about the processor switching time and redundancy features of compact logix and control logix.
I didn't think CompactLogix did hot backup?
I know this is a personal rant... but I see CPU redundancy as a gimmick to sell you more stuff. Without also having I/O redundancy, why make the most protected and stable part of the system redundant, without making the more vulnerable parts of the system redundant? If the primary processor faults on a problem, the backup processor is running the same program right? Well, it will fault too. Can't protect against that. So what does hot backup get you besides a lighter wallet and a more complex system?
Beauty and reliability is in simplicity ... Just my 2p.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
98
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
112
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
205
252
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
139
