Compact logix
rohitmane
Jan 2011
satara
31
My current project is on compact logix software redundancy for that i have 2 compact logix l32E and point i/o on device net network. any body know how to do it if known then please reply me .if any pdf that can help me how to do the redundancy.
CompactLogix does not support redundancy. Only ControlLogix with a very intentionally, specifically designed configuration...
I am with OZEE.
You might br able to make a rough failover system out of CompactLogix. Setting and breaking the Ethernet connection would probably be the hard part. How do You plan to make sure the data us the same in the 2 PLC if one fails and switches over.
I've done a compactlogix redundancy before over Devicenet, only devicenet support it. I forgot where to locate the guidelines but I'm sure it has..
regarding compact logix backup redundancy
My Recent senior had done the backup redundancy on compact logix . i have got information about compact logix backup redundancy. My Senior who had done redundancy are not ready to help and left out the job from our company . so please any body known about Redundancy can give a way for that. 40 percent have completed the work on it .
My Recent senior had done the backup redundancy on compact logix . i have got information about compact logix backup redundancy. My Senior who had done redundancy are not ready to help. so please any body known about Redundancy can give a way for that. 40 percent have completed the work on it . i have also got some pdf from rockwell site . here it is attach
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
131
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
135
I've blown the Output Transistor on the Output Card of a Compact Logix 1769-L24ER-QBFC1B It says J378. Does anyone know the replacement part...
209
271
I was wanting to see if anyone had any information on setting up a cub5 meter and getting the data to a Allen bradley PLC. I think i have the set...
144
