CompactLogix 1769-IQ16 input status
pauly
May 2002
South Wales,U.k
244
I have a problem with a CompactLogix 1769-IQ16 input card. The card is being used in sink mode, the OUTPUTS of the device connected to the card switch to zero (open collector output, NPN). The problem is that even though the LED's on the front of the input card are lit, the status of the inputs when monitored online momentarily go to zero every now and then.
I have measured the voltage between the input terminal and ground when the input is supposed to be on and it is sat at 0.53v. This looks correct to me. Any body have any ideas?
Using a laptop yes
I'm using a laptop. The status on the HMI that is looking at the same bits is changing as well. Eventhough the LED's are solid on on the front of the card as I said
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
100
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
490
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
590
Hey guys, On my system, i got prop valve controling cylinder on the left and right to adjust the center of a lumber before it get in a woodmill...
936
All Found myself in a situation where I need to flash the 1769_sdn Devicenet module from 2.002 to 4.004. I uploaded from the module but it has...
2,395
