compactlogix Ethernet question
ALVIN DAVIS
Mar 2004
SC
36
Hello
I am having some trouble setting up a generic card.
In my system (E+L) I'm using hex my setting is 50.
In the in and out on the rslogix card I am trying Dec 80 but have tried 40 and 160 if anyone use this module on a regular basis can give me a hand I sure would appreciate it.
Thanks in advance
What exactly is the device you are trying to connect ? I'm not even familiar with a vendor called "E + L".
Describe in detail the type of connection (8-bit, 16-bit, 32-bit, full I/O or Input only) and the Instance Numbers and Sizes you are using.
There are a minimum of six different fields you could be filling in for a Generic Ethernet Module connection, so we need to know which ones you're putting these values into.
Most devices that use the EtherNet/IP Generic Module object do come with instructions from their makers. Do you have access to any of that information ?
Hello I am looking into converting several SLC racks to CompactLogix using the 1747-AENTR module. These racks are currently RIO for a PLC5 in a...
2,549
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
378
150
Hi All, I have a requirement of communicating my 5380 CPU with Zebra ZT411 Printer. Is there any one who did this before ? Do we need to have...
939
Has anyone worked with a Cosmo Air Leak Tester(LS r-902) with Ethernet/Ip, to connect to A Compact Logix, I´m doing a proyect with this equipment...
2,063
