compactlogix firmware 12.22
Adam303
Aug 2009
Chicago
587
Hi
I need to download firmware 12.22 to a compactlogix controller. Currently the lowest version that I have is 13. Anyone know from where I can download the firmware? I tried AB web site but the last firmware that I see is 12.38
1769-l35e
I've personally never had an issue using a different minor rev level of firmware. That doesn't mean there may not be an issue. It's just that I've never had one. I suggest you try 12.38 unless you have and it caused a probelm.
Keith
Increases in Minor revision numbers means that it will be compatable with lesser minor revisions, within the same Major Revision. Minor revisions are released as compatable updates, usually to correct bugs and errors.
If an update changes the functionality in any way - it will require a new Major revision release
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
501
am having some issues with updating the firmware on a 1769-L35E,. The flash process will start and all the blocks are transferred, but at the end...
1,090
Does anybody know of a way I can upgrade a CompactLogix Module Firmware? We bought some "new" ones from EBay, but the firmware is 1.1
1,349
Hi, this is my very first thread. I am a PLC enthusiest and am setting up an AB compactlogix 1769-L35E controller with some relays at home to play...
3,098
I had a job today where a customer had outsourced a panel build to China and what they received was a well enough built panel but the PLC and HMI...
2,350
