CompactLogix Firmware Downgrade
Mark Cole
Nov 2014
Atlanta, Georgia
I have a 1769-L33ER running version 20.12 firmware and I would like to flash it to V21 to retain the comments in the controller and I would really like to flash it to 24 for the new logical organizer feature.
The possible issue is it has some Turck and Sick devices on Devicenet and I am not sure if running a higher controller firmware would likely cause issues with those as I don't have much devicenet experience and I am in sponge mode right now.
Also if I do flash it whats involved with downgrading it back to 20.12? I assume it's possible but how big of a deal is it?
The controller firmware won't affect the DeviceNet functionality at all.
But there's a big jump between v20 and later of the RSLogix and RSNetworx software.
If you do install v21 or newer Studio 5000 software, you absolutely must also upgrade RSLinx Classic and RSNetworx for DeviceNet. The EDS subsystem changed significantly and you cannot successfully mix Studio 5000 and pre-v21 RSNetworx.
Thank you Sir. I have a couple more small questions.
Will I need to update any of the EDS files for the DeviceNet Devices? I don't have RSNetworx Installed yet but I planned to install the latest with my V20 install on the same Virtual PC.
Would you think V24 would be ok to install at this point and flash? I know it's been out for a couple weeks now.
Sir can I flash back down to 20.12 if I need to? If so how involved is that?
Hello everyone, I just wanted to know if it's posible to downgrade the firmware of a compactlogix, I have a 1769-L32E with firmware 20 and I have...
10,854
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
501
am having some issues with updating the firmware on a 1769-L35E,. The flash process will start and all the blocks are transferred, but at the end...
1,090
Does anybody know of a way I can upgrade a CompactLogix Module Firmware? We bought some "new" ones from EBay, but the firmware is 1.1
1,349
Hi, this is my very first thread. I am a PLC enthusiest and am setting up an AB compactlogix 1769-L35E controller with some relays at home to play...
3,098
