CompactLogix Nonvolatile Memory Load / Store Not Enabled
habadeer
Aug 2012
NJ
43
I have backed up programs to a CompactLogix SD card probably fifty times in the last 3 years, so I am very familiar with the process. For some reason this CompactLogix L36ERM 5370 is not allowing storage of the program to the SD card even though the card is installed and the PLC is in remote program mode. See the attached image.
So far I've tried swapping the SD Card with no change. The SD cards are the cards made by AB.
Has anyone else ever encountered this? I'm worried that there is a problem with the controller itself.:confused:
Just asking the easy questions.
Is there a lock on the sd card? I think there is a wiper switch for read versus read/write.
Do you have another sd card that you can swap out?
Is the card pushed in correctly?
When you pull the card out do you see the connections on same side as sd card?
So after about an hour with tech support they finally stopped making me jump through hoops and conceded that the PLC is faulty. That explains why there was so little with regard to this issue.
Thanks Jim3846 for the reply and ideas.
Hi guys, A vendor recently left us with a machine which has a 5069-L320ER set to load from nonvolatile memory every time it powers up. We don't...
2,066
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
97
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
116
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
486
