Compactlogix on Ethernet network
shoeb
Sep 2008
NAGPUR
Is it possible to connect a CompactLogix L43 in a ethernet network; directly with other Compactlogix L43? How?
Please find the attached configuration.
I would say as long as you are not trying to pass time sensitive i/o between the two plcs, it should be just fine.
However, I am not sure about your ControlNet configuration on the left side; can you have redundant connections to just one i/o block and not all? Someone with more experience with ControlNet configuration may be able to confirm it.
Yeah the ControlNet config on the left is invalid. You cannot have "some" redundancy. All devices must have redundant connections or no devices can have it.
Alternatively, give that ControlLogix chassis two ControlNet cards. Then connect the redundant network to one, and the non-redundant to the other.
The diagram is a little grainy and I don't see any CompactLogix in there, but the ControlLogix on ethernet looks valid. CompactLogix wouldn't connect any differently to the ethernet.
The two computers at the top do not need to be connected as they are though. Just connect each to one switch. The switches are connected together so there is no need for each PC to be connected to both switches .
OG
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
369
144
Hi All, I have a requirement of communicating my 5380 CPU with Zebra ZT411 Printer. Is there any one who did this before ? Do we need to have...
936
Has anyone worked with a Cosmo Air Leak Tester(LS r-902) with Ethernet/Ip, to connect to A Compact Logix, I´m doing a proyect with this equipment...
2,061
Hello Everyone, A very important question: We are having trouble receiving analog output cards (5069-OF4) for our CompactLogix PLC racks. I am...
3,225
