CompactLogix to Modicon Quantum CPU Comms
CaptHook
Nov 2014
Portland, OR
18
Hey All,
I need to send a few bits between a new CompactLogix machine and a current existing Modicon Quantum 140CPU65260.
Has anyone ever set up basic ethernet communications between these two?
Thanks!
Steve
When I encountered this situation, I used the InTouch HMI that was common to both PLCs as sort of a virtual router. Read a tag from one PLC and then use scripting to write that value to a tag in the other PLC.
If your HMI can't broker the comms, then I recommend a network gateway like the very easy-to-set-up units from Real Time Automation.
While you could probably do this with the socket-based Modbus/TCP client sample code that's installed with Studio 5000, that takes up a bunch of memory, isn't particularly elegant, and will take time to troubleshoot.
The Red Lion datastation Plus is really good for this application. I have a few now for interfacing between old SLCs and our new modicon M340s.
Hey guys, I am trying to make an Allen Bradley Compactlogix and a Modicon Quantum talk to each other using a Red Lion Data Station. So far I've...
3,012
Hi guys the system A using Modicon controller(BMXP342020, and system B using CompactLogix controller, we want to setup a communication between...
4,552
We have a Modicon PLC that is connected to the Ethernet Network and we have three CompactLogix PLC's connected on this network as well.. I need to...
7,059
The plant is using Modicon PLC’s for the plant control system. Is there an interface for the communications between the AB controller and the...
4,839
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
97
