Compare a Combo Box value with a record in a table
SeanWRT
Jun 2016
Windsor, Ontario
17
Hey everyone thanks for the help. Again I am really new to programming in InTouch.
I have a need to find a record/value in a table based on the value in a combo box.
DB Table is
Reason_code | Description | 2 Other Columns
SQLWhere = reason_code (integer) where Description = Combo_Box_1.value
Does that make sense, and can anyone provide a little direction?
Thanks,
ST
Thanks GC for the quick response. The first link will not help. I do not want the item number in the list provided, I need the actual reason code associated with that record.
The first example only gives you the item value based on it's place in the list provided. We have skipped items in the list and therefore need to call up the actual record from the database.
I am currently investigating the second option.
S
Help please. Im new to Omron and have a machine down. I have a compare = for barcode label scan. I've attached two pics. On the Mnemonics you can...
636
Hi everyone! Accidentally closed it and it wont appear again. Checked and unchecked the option and seem to make no difference. Running v7.10.00...
1,941
I'm working on an array that contains a UDT of 5 Items Array[4] DataType[0] - Part 1 - Part 2 - Part 3 - Part 4...
851
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,279
Hello experts, I am just starting with AB programing, I have a questions regarding a compare done in an old RSlogix500 and causing me issues when...
1,957
