Compare with Wago E-****pit
orense
Apr 2006
Norway
196
I am used to using Siemens Simatic S7. I often travel to existing sites, so the compare function is important to me, because I need to verify that I have the correct as-built files before I download anything.
These days we are starting to use Wago, and I am new to the E-****pit software. Does anyone know if it has comparable compare functions as Simatic S7?
Since these plc solutions are built on the same IEC standard, I would expect that it has something similar?
Thanks!
Not sure about e ****pit but their Codesys Wago I/O Pro (v2.3 Codesys software) does offer the compare functionality.
I assume same goes for the E ****pit.
Help please. Im new to Omron and have a machine down. I have a compare = for barcode label scan. I've attached two pics. On the Mnemonics you can...
663
Hi everyone! Accidentally closed it and it wont appear again. Checked and unchecked the option and seem to make no difference. Running v7.10.00...
1,975
I'm working on an array that contains a UDT of 5 Items Array[4] DataType[0] - Part 1 - Part 2 - Part 3 - Part 4...
860
Hi. I have 2 files where I would like to see the ladder logic differences (similar to the Rockwell compare function). I am using TISoft Siemens...
1,288
Hello experts, I am just starting with AB programing, I have a questions regarding a compare done in an old RSlogix500 and causing me issues when...
1,976
