Config for I/O Adapter
mark thompson
Mar 2014
Brentwood Ca.
We currently have a PLC 5/25 and we are replacing it with a PLC 5/40. WE also currently have 1771ASB Remote I/O Adapter that is configed with the 5/25.We are using the adapter as a scanner for outputs only.When we download the program and convert to the 5/40 all is good. Channel 1A we are using for DH+. Channel 1b is for remote I/O Scanner. When we do an auto config it promts us make sure I/0 status file exsisst. we tried edit channel properties for 1B GETTING CLOSER but still not working. Its 2 slot addressing.
not sure if this is what you're asking for ... but - the AutoConfigure feature won't work without a "scratchpad" to hold its data ... basically you just pick and enter an UNused number - and the RSLogix5 software will create the file for you ... then try the AutoConfigure feature again ...
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
88
Hi all, I have some difficulties with programming a NAT config in my Scalance SC636-2C When programming the NAT-table i'm not able to reach my...
222
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
87
Hi everyone, I’m trying to copy the configuration from one MVI69-MCM to another. I am having no luck establishing serial comms with the device...
94
I have 3 new PowerFlex 7000 VFD's. Rockwell was out to do some checking before startup. These are part of a larger electrical project. I gave the...
342
