Configure S71200 with external NTP server problem???
naturephoenix
Jan 2015
Vienn
181
I got Meinberg as NTP server, and it is in same network as My S71200 PLC.
I went (Device configuration -> Ethernet Port ->time synchronization) and entered Meinberg IP address but once I go online my PLC keeps sinchronizing to my PG-PC interface which means to my PC.
There is option "disable" PG-PC synchronization but it keeps returning to be enabled.
Can anyone help regarding this issue?
As far as I know, a 1200 will get its time from your PG when you are setting the time in Online & diagnostics. THis isn't a constant thing, it is a one-shot.
It could be that there is an HMI setting the PLC time.
Nope it is not HMI? But You have said that PG_PC is giving PLCS71200 time only when I'm in Online and diagnostic mode?
That means when I'm not online PLC is taking time from my NTP server?
If that is the case there is no problem at all.
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
164
Hello, I am trying to connect a Stride Analog Output module to a 1769 CompactLogix via Ethernet. I added a new Generic Ethernet Module for the...
240
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
153
Hi all, the machine I am programming the Rockwell PLC for has about 100 parameters that need to be adjusted for every customer. I would like to...
20
1,981
Within the last week or so, PME has crashed whenever I try to open a configure IO screen. I am running V8.0 Build 6215. Offline configuration of...
401
