Configuring OPTO22 IO in codesys
dduquette2141
Jun 2022
Massachusetts
Hello everyone,
I am looking for an easier way to configure all my IO for an OPTO22 PLC. I am developing in Codesys I have a GRV-EPIC-PR1 with a bunch of GRV-ITM-12 analog input cards. I have 10 systems that I will be configuring 96 channels per system. I know there has to be a way to configure the input channels using a function block some way I just can't seem to figure it out.
If it matters all the channels are Type K thermocouples.
This is my first time using Codesys. It has been a bit of a struggle.
Hello all and happy Friday, I'm curious if anyone here has experience sending data over an Anybus Bolt II (HMS AWB6001-A) using a Compact Logix...
771
Greetings to all. We have SST-SR4-CLX-RLL (Molex Modbus module) in remote backplane. The remote backplane, containing SST-SR4-CLX-RLL module, is...
653
disclaimer- 1,no one in their right mind would pick this configuration but I want to try and get it working. 2, my MB knowledge is sketchy at...
1,144
When configuring redundant ethernet cards, will the mac address change along with the IP address. A friend is having problems with IP security...
1,265
I am working with an Emerson CPL410 PLC that is connected to a Siemens AI 8xU/I/RTD/TC ST (6ES7531-7K00-0AB0) via Profinet (and a Siemens Scanner...
1,542
