Confusion on PV+ 1000
boiler-todd
Nov 2003
Layton, UT
47
I have two panel view 1000+ HMI's that are tied to a robot pick and place into a slotted tote. Both PV+'s show the same data a one is the Master screen and the other is a remote unit. Both work over ethernet to a 505 processor via the same switch.
Here is what happens... When the Robot places a pick in the tote the visual grid of the tote changes that location from yeloo to green to show full and then updates the tote count by the number in the pick. 75-80 parts depending on the stack.
Here is what's happening... The remote unit takes over 1 minute to refresh data. Sometimes we have to toggle between screens to get it to change data. The master HMI gives us data realtime as the pick gets completed. Any reason why this delay would happen. This wasn't like this originally, I believe.
Any input would be appreciated. Todd
From your description, it sounds like the Ethernet connection to the remote-mounted PV+ terminal has degraded.
If you have a managed Ethernet switch you can query that to determine if there are noise problems on that link. You can also read the Diagnostic counters from the SLC-5/05 using RSLinx Classic or by directing a web browser to its IP address.
Do you have access to the FactoryTalk View Studio software that is used to edit the PV+ terminal applications ? You might use that to build a test application, or to add a diagnostic display with the Predefined Items from RSLinx Enterprise that give you information about the PV+ Ethernet performance.
How long is that Ethernet cable to the remote unit ?
Yeah I would load a simple app, 1 screen with 1 numerical indicator, see what happens.
I would replace or try to test the cables also.
Hello, all, I am new here and pretty new to PLC'S. Closest thing I have to PLC experience is with avionics. At my new job I am a welding engineer...
808
I am working on some documentation in preparation for updating firmware around our plant. On one particular PLC, the point IO has two different...
717
When enabling a FOR instruction does the index set to the initial value before the first execution of the Called Routine? e.g. Initial Value = 6...
1,480
Hello, My apologies in advance if this is a stupid question. I have done a fair amount of work in Factorytalk View machine edition, and I am...
1,227
I'm looking to purchase either GX works2 or works3 for a Q series rack I purchased off of ebay. Now the confusion comes from either purchasing...
1,375
