Seppo:
Yes, it is working with FX0S, at least this the only PLC I have today here.
I got the adapter last night to try until Monday. It is still not in the box, but I saw box siting on the bench.
It came with 3ft cord, but I was told, that they will not make it longer than 2ft, most likely 1ft (30cm).
Module plugs into the 8 pin programming port and takes the power out of CPU.
It comes with a
FREE serial port redirect driver: for Beijer module you have to buy it separately!
Here is a problem they have that stopping them from releasing the module:
Module requires about 240 ma from 5V supply.
They can't get any info if programming port is capable to provide this power to the module.
Looks like it will work AS IS:
- with all FX1N and FX0N PLCs, if you have only one additional module instead of reccomened two and not using high power modules like profibus.
- with all FX2N and FX2NC PLC, as long as you add 240ma in extension power calculations.
It works with FX0S-14MR-ES test PLC, but it is possible I am overloading it: switching power supply on PLC makes some noise but no overload trip.
They told me that I can plug in an external power source 5V - this will automatically disable usage of PLC PS, but I don't like a wall transformer type adapter.
They told me that adapter will be redesigned next week to accomodate external 24DC power source:
it will be small DIN-Rail type of housing with short pigtail 8 pin cable to plug into th CPU port.
This will add probably add $20-30 to the price
I will play with adapter till Monday and provide info for you guys and my friends at
plccables.com
If someone needs more info or have comments - ask me or ask plccables directly.
