Connect to CPU 315-2 DP
rakkso
Oct 2013
Helsingborg
Hi. Im trying to connect to a Siemens CPU 315-2 DP via VMWare.
My laptop doesn't have any COM ports, so I'm using a usb to rs232 converter, connected to a PC adapter (MPI).
CPU: 315-2AG10-0AB0
PC Adapter: 6ES7 972-0CA21-0XA0
So when i try to connect/ tranfer HW config or blocks, the green LED on the adapter lights up, then i get this error: "Online: The connection to the target module cannot be established." (33:16662).
I have checked settings in the device manager and PG/PC interface, and they match.
Anybody know what I'm doing wrong?
Maybe you already checked but is there a small switch on the side of the pc adaptor for selecting 19k or 38k ? does this match the local settings in S7?
I can tell you that the old type serial pc adaptor + usb/serial adaptor + XP mode (on W7) + Step 7 5.5 does work. I don't know about VMware sorry
Yup they match! Hmm okay, I'm running XP in VMWare. So frustrating that it doesn't work out. But the green active LED on the adapter lights up, so there must be some kind of communication. :/
I should also mention that the STOP LED on the PLC is continuously flashing. Even with the PLC in RUN. Don't know what to make of that.
I have a stand alone machine with a cpu 315 dp and no cp. I want to intergrate it into a existing network ( already,contains cpu 414's, pc's...
6,226
Hi, I have an Omron PLC (CQM1H-61CPU) connected to an Omron HMI (NT631C). In order to connect a PC to them, I want to know: 1- Is the cable...
875
Hello Friends I need to monitor a PLC Vipa. Which software and cable do i need? The upload will have the comments? Thanks in advance.
1,550
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I...
3,074
Hi. I have B&R Power Panel 4PP320.1043-31, CP1583 and wont to connect it together. I create simple project in Automation Studio for panel only and...
3,204
