iant Lifetime Supporting Member + Moderator Join Date May 2002 Location Melbourne Posts 3,691 Jul 14, 2016 #16 CCW does not use factory talk. Try direct access via a web browser.
fella Member F Join Date Jul 2016 Location Texas Posts 3 Jul 15, 2016 #17 The standard edition does not use factory talk activation, the developer edition does. If you have a toolkit, you can check to see if you have the developer license, otherwise you will have to use the standard(free) edition.
pr978 Member P Join Date Oct 2014 Location UK Posts 11 Oct 3, 2016 #18 CCW numeric data entry Hi Guys; I have a problem with saving values in Numeric data entry. On every power down; all numeric value lose its value and come back with "0". I have check everything I can but can't find any setting or anything which lets me to save it. Any help is much appreciated.
iant Lifetime Supporting Member + Moderator Join Date May 2002 Location Melbourne Posts 3,691 Oct 3, 2016 #19 Check your variable name. Make sure it's a global retentative tag I'm nowhere near my notebook at the moment But I will check and confirm later
damica1 Member D Join Date Aug 2015 Location Illinois Posts 839 Oct 3, 2016 #20 When you create your variable make sure you check the "Retain" in the parameter for the variable.
