Connecting a panelview plus to a second network
stu
Aug 2005
England
784
Hi guys
Just a thought
I have a pvp on a 192.168.1.xxx network if I wanted to add a the screen to a second network say 192.168.0.xxx could I change the subnet on the hmi ?
It’s just a thought ? Can you see any issues
The 192.168.1.xxx subnet needs a router/gateway that routes packets to the 192.168.0.xxx but this is a task of a network administrator rather than a plc/hmi programmer, then on this screen config you will need to put the 192.168.0.xxx IP of the second PLC and the IP of the new router/gateway
Another solution is to physically join both networks and change all the subnet masks to 255.255.254.0
93
Hello all! Can someone shed some light on this? I am trying to connect a PVP 6 to a PLC-5/30 through the serial ports because the old touch...
539
What some ways to connect an Ethernet only PanelView Plus to a SLC 5/04 without upgrading it to a SLC 5/05?
4,996
is it possible to comunicate a powerflex 753 (ccw) using ethernet 20-750-ENETR card to a panelview plus 6 1250 (factorytalk view studio me)...
1,496
I am trying to set up a PV+ 1000 to monitor plant wide processes. I am not having any trouble setting up the Control Logix and SLCs that I have...
6,658
