Connecting cable for S7-1200
aqueousdan
Jan 2016
uk
32
Hi there guys,
At work we have some Siemens S7-1200 PLCs and have just got the Step 7 Basic software. Typically it has got to this point where we have the PLC and the software but no cable :sick:
Looking it up I need am IE TP cable. Is this the same as a standard ethernet just a bit more rugged?
Thanks for your help guys,
Dan
That is just a standard ethernet cable. But with a siemens pricetag on it i assume ;)
Any TP cable that you can get your hands on is fine and will do the job.
Can you use step 7 basic software with S7-1200 series CPU's? I thought TIA portal was needed for the newer generation s7-1200 and s7-1500 CPUs? We are currently using TIA portal v13 for our (limited) S7-1200 series CPU controlled machines.
I am currently playing about on a test rig with a S7-315 and a S7-1212C CPU. I'm using a spare S7-1212C CPU purely as an interface as it has Modbus communications capability built in. To program the 1212C CPU I'm using TIA portal v13, but for the 315 CPU I'm using Step 7 Simatic Manager v5.5 (I Think!)
But as JeckeData says, any ethernet cable will do! I'm using a random selection of ethernet cables.
There are two versions of Step 7 TIA Portal - Basic for the S7-1200 family and Professional for the S7-300/400 (newer versions), 1200 and 1500.
For connecting to a Micrologix through a 1761-NET-AIC, the manual specifies that you should use "RS 232 Communication Cables Cable, Cat. No...
1,370
Do this happened to any of you ? I just succeeded connecting a ml1400 true a new XPmode VM by the means of ethernet. I used a direct cable from...
3,687
Hi all :) we have one following PLC. Platform :controlnet Processor :PLC5/40C Series :E-2000files/extended we bought one USB to...
2,173
Hi guys, I have a Siemens CP341-RS422/485 module and I am trying to establish MODBUS communication to a series of Multilin269 / 469 protection...
6,257
Hello everyone, first of all thankyou for all the help you've given me through other peoples' Q&A's. My situation is; -I am halfway through...
4,569
