Connecting control logix and HMI 700 to PC
macstorm
Jan 2014
india
17
Hi all,
I have connected my PC, PLC AB 1756 control logix and HMI panelview 700 to SG92-24-AS cisco switch.
I am able to ping all the devices from the PC. But when I try to download the program from studio 5000 it says that the communication...
In the RSLinx i could view the HMI and PLC connected.
What may the problem.
Hi, just starting to learn citect Scada, and im trying to connect it to the control logix, i have followed all the instructions in the "help"...
3,913
I am wondering what would be the best way to connect our 2 Process control networks to a new control logix controller (L5561 ) Can you install two...
3,813
We've got a portable cooling pump which circulates a coolant oil. The spec says it can be remotely operated (coolant START/STOP), via a 3-pin...
1,488
I've been resurrecting an older machine from 2005 and have had good success with help from the forum. Got connected to the PLC and was able to...
1,391
I am using FactoryTalk VIEW alarm server to set level alarms on tags in the PLC. I am pointing the Enable and Disable bits for the alarms to bits...
4,249
