Connecting my Laptop to 1794-AENT adapter
Are you asking:
  1. How do I physically plug the cable in?
  2. What type of cable do I use?
  3. How do I setup communications in RSLinx?
My guess is some combination of #2 and/or #3. But since you didn't specify..............
As for cabling. Preferrably you would have a switch. Plug your computer into the switch and using a separate cable, plug the AENT into the same switch. Or plug directly from the PC into the AENT using an Ethernet crossover cable. You could even plug your PC into a switch and then plug the AENT into a separate switch and then run a cable from one switch to the other!
So, give us details on what you really need!
OG
OG
These days a crossover cable is no longer required. I've been connecting my PC to AB hardware with standard patch cable for quite a while now. They auto sense and switch.
Yes, more details.
Hi; I have Laptop Lenovo Thinkpad (W10) which don't have built-in Bluetooth. I have a PLC having Bluetooth communication device. I wanted to...
150
Hello everyone, i have a small issue that i need to solve. I had programmed a PLC last year, it was allen Bradley's L24ER , and now the PLC and...
2,712
Hey guys, I'm trying to connect my laptop to an old SLC500 PLC. It has a DH-485 port on it and I have to configure a driver for it on taking. I...
1,412
Hi, I am very new to PLC's I am currently doing a project for college and wanted to be able to test my project at home, I am using an FX1S-20MR...
8,370
im looking to connect with my laptop by serial port and drive explorer w/ rs1 adapter, i have the adapter and my ab dealer says to use a null...
2,085
