Connecting PC to MPI interface
Rietvelder
Oct 2004
Hello guys,
I'm new on board and have a question about setting up a connection between PC and PLC s7-300 CPU314. I know it's an RS232/RS485 connector and I sure know were to buy it but can I make it myself? What's special on this adapter? Are there diagrams to make my own adapter? I Searched the whole web but found nothing.
Thanx in advance.
Rietvelder
No, you can't make your own MPI adapter. Siemens guards that information very closely. You must purchase the adapter from Siemens, or one of the 3rd party adapters available. Be very careful with the cables, also, the MPI cable that connects the CPU to the adapter is NOT an RS232 cable. The pin-out is different, plus it carries 24vdc from the CPU to power the adapter. If you use a standard serial cable, the life-span of your adapter will be less than a second. Well I can vouch for that on a USB adapter, not sure how the old serial adapter would hold up.
K
Hi all :) I am a little noob on WinCC and i would kindly ask you all for some help. At my plant we use WinCC as the main control system. The only...
5,146
K
We have the following scenario where we need a Controllogix PLC to be able to read data from Siemens PLCs on two separate networks. Controllogix...
5,775
We have an existing network of 5 Siemens S7 315 and 313 PLCs communicating via MPI. We want to connect a Contrologix PLC to the network that will...
2,466
I have to buy a new cable so I can connect my new laptop to the PLC. Today I have a CP5512 and I'm looking for the same functionality via USB or...
5,356
We have an S7 313C CPU that was gathering dust on the shelf, so I decided to put it to good use as a training/demo PLC. I powered it up, installed...
3,909
