help connecting to S7 CPU via MPI
katratzi
Mar 2005
210
We have an S7 313C CPU that was gathering dust on the shelf, so
I decided to put it to good use as a training/demo PLC. I powered it up, installed a new mmc card and....... nothing. I cannot get
connected through the MPI port.
There are no error lights only the power and 5volt lights are on, and they are both green. I have performed a memory reset per
the manual, checked baud rates, checked MPI addresses.
I can change the processor from RUN to STOP by the switch on the front panel, but that is about all that I can do. The error
message that Simatic manager shows is:
" 33:16944 Online: Cannot find active partner. "
Or something very similar to the above phrase. I am sure the
numeric error code is correct.
Anyone have any ideas as to what I can try next??
Have you tried it without the card? maybe the card has something on it?? just a guess
Hi. yes, I tried it first without the MMC card, but when that did not work, I was told by
local distributor that the card was necessary for cpu to begin operation.
I am wondering that maybe something is wrong with this processor,
but no warning or fault lights and no communication, how do I find out the problem?
(this is a new mmc card)
Follow the memory reset procedure using the switch on the front.
I have had the same problem with new units, once I reset the CPU using the switch- I was then able to see MPI address 2 using accessible nodes
For everyone hanging on the edge of their seat, it was a bad
MPI port on the processor. :)
Hello, I am facing problem in installing the cp343 lean with cpu 315-2 pn/dp. the cpu is conected with 4 distributer controllers as for...
1,548
This is my first post, so hello everyone! I am new to S7 programming and have a S7-214 CPU. I am using a HP laptop without a serial port with...
4,814
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,353
Hi all Has anyone connected a baumer verisens vision to a tia I have set up the gsd file and have added the verisens to the network On setting...
3,078
Dear all, In a previous post I asked if someone had the software for an old Taian TP02. We used to sell our bandsaw machines with these PLCs a...
2,775
