Connecting pg on Profibus node
Plc_User
Dec 2005
Belgium
317
Sometimes you want to connect your pg to a Profibus node somewhere in the field, because you need to that part of the machine while monitoring in the S7-programm.
If you are lucky, there is a Profibus connector that has a connection where the cable from the pg can be put on.
Somtimes there no such a connector.
Does there exist some piece that can be put between the profibus node and the connector where I can plug also my computer in. You could offcourse replace the orignal connector with one that provides acces with a pg, but I do not want to screw open anything, only pull out the original connector, put somthing on the profibus slave and plug the original connector on to it. Also because we are making a stub line, it would be nice if the 'special connector' has some build in repeater to avoid problems with stub lines.
Hope you guys have some advice, because this should be a common problem.
You can use a PROFIBUS connector with a PG interface, just plug it in behind the original connector :) Be aware that you'll have to disconnect the slave if you do this.
Change all your node profibus connectors to these, they allow you to plug a pg into them without removing anything.
Siemens part number 6ES7 972-0BB12-0XA0.
Better still, if you can, if your system has an ethernet module, add a wireless router, that way you can walk around the machine without cables :ROFLMAO:. saves having two guys looking for a fault with two way radios. 🍻
Be aware..
Some Siemens devices (as HMI's) do not provide 24VDC output at Profibus port, so conect to such port with PC-Adapter cable is NOT possible!
Hello, I'm Alex from Spain (sorry for my bad english). Firstly, I'm a newbie at Siemens PLCs and HMI, I have been reading this forum for hours...
1,601
Hi everybody, I'm a new member, everyone who could pleased show me how to config S7-300 and BK3150 communication, i tried to do it but when i...
3,519
Hello, Is it possible to use this: http://www.moxa.com/product/NPort_IA5000A_Series.htm to program a S7-300 PLC (MPI or PROFIBUS).
1,922
Dear All, I'm using S7300 CPU315-PN/DP. As the manual states that its integrated RS485 port can function as MPI, DP Master and DP Slave. When I...
2,658
I'm having a little problem configuring my WinCC project. I have a Profibus network with 1 master and 8 slaves (each PLC with alarm_S data)...
3,649
