Connection between CLX and MP277
Hubert22
Feb 2015
Denmark
Hi all
Long time lurker, new member.
I have a problem with at little project at home. I have a Siemens Multi Panel MP277 and a 1756-L55 controller with a 1746-ENBT/A. I'm trying to setup the Communications, but can't seem to get it right. Not sure where the fault is but here are some setting i've tryed.
In the Mp277 communiction path is set to 1,0 (rack,slot)
IP is in the same range as the 1756-L55
Tags are called the same as 1756-L55, and connections set to 1756-L55.
I can ping the 1756-L55 from the MP277.
They are both connected to my router, is this a problem ?
Is there something i should setup on the 1756-L55 ?
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
310
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
229
Good Morning, I got an IMO HD2 inverter with 2 slots and on the first slot I put the ethernet module (HD2-E-ENET) and the second one is free...
1,266
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,215
Hello, I'm gonna try to make this as clear as possible. For a project, we have 3 Unitronics PLC's controlling each a machine. The company that...
3,419
