connection multiple CPU with OPC
Ok nevermind i will search further
An other question,
I also use an 1200CPU the connection is established but here you need to insert you parameters manually but when i do this i get an error: the item does not excist in the server space
i have googled this but found nothing yet
hello everyone i hope you all have a good time what is the maximum OMS+ connection for wincc 7.5 ? this is maybe a repetitive question but i...
639
Hi, I encounter a problem trying to get online to a CPU315, This CPU is part of a MPI network with multiple CPU including a CPU414, When I do...
1,493
I want to connect 2 plc's (in the same Siemens S7 project) to one HMI (siemens MP277). I am using WinCC flexible. I have done this in the past...
5,492
We've been implementing a setup allowing us to remote connect via the Internet (using the customers internet connection - jumping onto their LAN)...
4,413
Is it possible to connect muliple SCADA station PC's all are connected with Nokia 30 GSM modems, with AB's SLC 5/03 plc which is also connected...
3,177
