Dear all,
Now,I've a PanelView 1000,and I want to connect it to SLC 5/05 through ETHERNET .After I finalized my tags and adjusted the connection in PLC and Panelview.I connected an Ethernet cable between them but no symptoms of connection , I'm able to log to plc through Ethernet and the same for panel view .when PLC to panel view no led lit in both sides. Here are images for my configuration in both slc and pv.
what type of ethernet cable is suitable is it direct or reverse?,
I only need to make connection between them.what am i missing here?
Thanks in advance
regards
Thanks in advance
regards
